bradenspamlmao
Jul 17, 2021Follower
Not finding an internet connection
I have an internet plan with my isp, but everytime I go to try and get it connected and ready for use it doesnt ever find an internet connection. Really have no idea how to explain this or what to do...
MoralMinority
Jul 22, 2021Aspirant
WiFi, but No Internet
- Turn off router (button on back) and unplug modem
- Plug in modem and wait for it to fully power on
- Turn on router, Internet may not light
- Use a computer connected to ethernet or your WiFi
- Open routerlogin.net
- Login username: admin and password: password (this is the default if you did not change it)
- On the home screen, if the Internet block is red “No Internet”, click it.
- This takes you to the Internet settings
- Go to “Router MAC Address” at the bottom of the page.
- Select “Use This MAC Address”
- If the address is blank use MAC Address from label on bottom of router
- I add colons between ever 2 value, like this is XX:XX:XX:XX:XX:XX
- Click the green “Apply” button at the top of page, and wait.
- After it finishes and screen refreshes, go back to Home page. It should say Internet GOOD.
- Sometimes it logs you out and you need to login again (Step 6)
- Click “Logout”
