vaibhavrm
Jun 12, 2021Initiate
Not getting 600 MBPS speed through wifi for C7000v2
Hi I have a xfinity connection with 600 MBPS speed, when I am using my wifi max speed I get is around 250 MBPS however when I connect any laptop via LAN I get proper 600 mbps. I am novice when it com...
Jun 13, 2021Guru - Experienced User
You won't.
the 250-300mbps is about all you can expect from the wifi on that device.
I could go into the long explaination of why but its been gone over many times.
Read this article on misunderstandings of wifi.
vaibhavrm
Jun 13, 2021Initiate
Understood, any model recommendation which will give me 600 mbps?
- plemansJun 13, 2021Guru - Experienced User
Sadly it isn't just a "what router will give me those speeds" but what device are you using.
A lot of times the bottleneck isn't necessarily the router but the device you're using and the environment you're in.
I'd recommend looking at the article I linked to for info on what to expect. then I'd recommend looking at smallnetbuilder for some actual tested reviews of routers.
