Nov 05, 2025Guru - Experienced User
NOTICE: CM3000 cable modem v6.01.04 Firmware Released
Getting some reports that this version of FW is being seen on CM3000 series modems from CC/XF ISP. Not sure if other ISPs will be seeing this. Maybe at some point.
This seems to follow up on la...
Wavicle
Aug 12, 2026Aspirant
Event Log:
| Time | Priority | Description |
| Wed Aug 12 13:20:39 2026 | (Warning (5)) | TCS Partial Service;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Wed Aug 12 12:33:52 2026 | (Error (4)) | DBC-ACK not received;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Wed Aug 12 12:33:49 2026 | (Warning (5)) | TCS Partial Service;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Wed Aug 12 12:32:50 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Wed Aug 12 12:32:10 2026 | (Notice (6)) | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 9 13.;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Wed Aug 12 12:31:10 2026 | (Warning (5)) | Dynamic Range Window violation |
| Wed Aug 12 12:31:10 2026 | (Warning (5)) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Wed Aug 12 12:31:03 2026 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Wed Aug 12 12:30:58 2026 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | (Warning (5)) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | (Notice (6)) | Honoring MDD; IP provisioning mode = IPv4 |
| Time Not Established | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Wed Aug 12 12:29:46 2026 | (Critical (3)) | Resetting the cable modem due to docsDevResetNow |
| Wed Aug 12 12:28:06 2026 | (Critical (3)) | Resetting the cable modem due to docsDevResetNow |
| Wed Aug 12 11:59:09 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Wed Aug 12 10:30:51 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Tue Aug 11 17:35:05 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Tue Aug 11 15:01:22 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Sun Aug 09 21:24:04 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Sat Aug 08 19:54:40 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Sat Aug 08 06:40:18 2026 | (Critical (3)) | No Ranging Response received - T3 time-out;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Sat Aug 08 06:40:13 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Fri Aug 07 10:05:00 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Fri Aug 07 08:39:19 2026 | (Critical (3)) | No Ranging Response received - T3 time-out;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Fri Aug 07 08:39:17 2026 | (Critical (3)) | No Ranging Response received - T3 time-out;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Thu Aug 06 12:59:10 2026 | (Critical (3)) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Thu Aug 06 12:55:38 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jul 23 06:40:36 2026 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1; |
