Nov 05, 2025Guru - Experienced User
NOTICE: CM3000 cable modem v6.01.04 Firmware Released
Getting some reports that this version of FW is being seen on CM3000 series modems from CC/XF ISP. Not sure if other ISPs will be seeing this. Maybe at some point.
This seems to follow up on la...
Wavicle
Aug 12, 2026Aspirant
The CM3000 is connected directly to a TP-Link Omada Gateway/Router model number ER707-M2 into the 2.5G port. It then goes into a TP-Link Omada POE Switch model number SSG2218P. All TP-Link hardware is managed by an OC220 Controller and all firmware is updated by TP-Link to the latest as of 12-August-2026.
