ChristineT
Feb 23, 2023Administrator
NOTICE: My Nighthawk CAX30 Cable Modem Router is not connecting to the Internet; what do I do
Hello CAX30 Community,
We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that might have resulted in an interruption to your Internet service. Please visit NETGEAR.com/FixCAX...
Feb 23, 2023Guru - Experienced User
For those CAX30 users that can not access the modems web page, even after a factory reset, I got some information that TFTP method of loading FW on the modem can help resolve units that may not be accessible to it's web UI normally.
This process can be used to load the v1.4x FW on to the modem for the router portion and should hopefully bring back good operation of the modem:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Get the v1.4x FW file from here first:
https://kb.netgear.com/000065403
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=hXhMgQS5k1o
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a Windows 7 PC and the TFTP worked.
Windows TFTP: https://pjo2.github.io/tftpd64/
Apple Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Can give this TFTP program a try as well:
https://github.com/jclehner/nmrpflash
If all this fails, users will need to make contact with NG support:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
