Spraragen88
Aug 23, 2025Follower
Now Spectrum has updated the CM3000 to version 6.01.03 - they refuse to roll it back
This darn broken firmware has made its way to Spectrum. They refuse to believe the only solution is to rollback to 5.0.X as proven method by Xfinity and other ISPs who dealt with this mess months ago...
KristopherK2024
Jul 31, 2025Aspirant
Hello:
Thought I would add to the issue regarding Cox Cable.
Have had same issue since Cox updated the CM3000 to version 6.01.03, likely in May. Have had 4 Cox service calls and last one finally advised either modem itself or bad firmware. He did advise he doubted Cox had ability to do firmware rollback, as had never heard of that happening. He advised if I got a new CM3000, unless the problem version had been suspended by Cox, the new modem would likely get immediately updated as part of the provisioning process. His only recommendation was to wait till next firmware update and see if fixed issues.
That is DOA; so likely giving it another week or so to see if Cox Cable initiates a rollback or will just buy Arris S34 and be done with this nonsense.
Find it hard to believe the firmware issue made it past both NETGEAR and Cox. Have usually had good luck with NETGEAR as also have Orbi 972 and it has been great.
Thanks
Kris
KristopherK2024
Got it new in March from Netgear under warranty; was replacement unit as my old one had several of the LED lights burn out. If I had been thinking would have confirmed the firmware on it when arrived. Started acting up in May, which is when the cox tech said he thought Cox had pushed out V6 of firmware.
Will keep on Cox ISP, but even the Cox tech said he was unable to directly interface with the DOCSIS engineer group. With Cox's pending merger with Spectrum not sure how anything is going to be handled going forward. 1st and 2nd tier customer support, off shore mostly, is terrible, I know more than they do, which is not much.
- FURRYe38Aug 01, 2025Guru - Experienced User
OK, send your info to NG. Ya v6 came out a few months ago. Hopefully NG can make contact with Cox in that direction and help them push prior working FW to your modem.
