Silos06
Jun 14, 2018Aspirant
Older 2015 cable modem. How should one fix the 4 ethernet outputs.
Not gettting any connectivity out of the wired 4 ports on the rear. Not sure my provider says theres a little bit low out put. Would eventually try it on the other modem wires to test it cause it is ...
DarrenM
Jun 18, 2018Sr. NETGEAR Moderator
Make sure the modem/router is not in bridge mode and has the router portion active in the settings.
DarrenM
- Silos06Jun 26, 2018Aspirant
yea i tried with the smart phone app and on my pc to get on routerlogin.net. I cant even get on it to look at settings and its giving a wifi signal. Thinking its time for new 1
- DarrenMJun 28, 2018Sr. NETGEAR Moderator
try to go to 192.168.0.1 or 192.168.100.1 see if that pulls up the settings.
DarrenM
