Silos06's avatar
Silos06
Older 2015 cable modem. How should one fix the 4 ethernet outputs.
Not gettting any connectivity out of the wired 4 ports on the rear. Not sure my provider says theres a little bit low out put. Would eventually try it on the other modem wires to test it cause it is ...
