donwillcomputer
Dec 29, 2022Follower
Oldest Firmware Download for Nighthawk X4S AC3200 WiFi Cable Modem Router
Hello, I need the oldest firmware download link for Nighthawk X4S AC3200 WiFi Cable Modem Router. If anyone can provide this link that would be very helpful.
Kitsap
Dec 29, 2022Master
donwillcomputer wrote:Hello,
Go up to the top of this page and click on Downloads. In the box enter your model number, R7800 and select it from the list. On the right hand side is a column with the most recent firmware. At the bottom right edge of the column click on the downward caret and additional options will be provided. At the very bottom is firmware version 1.0.0.28 which dates from 11/28/2016.
https://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.0.28.zip
You are not going to be able to update from the earliest version to most current in one step. You might have to update in several iterations. When you are done, be sure and perform a firmware default reset.
