Yugpot
May 21, 2023Aspirant
On off switch
I want a nighthawk 67 800. Where is the on off switch?
May 21, 2023Guru - Experienced User
What router do you have?
You gave not much info
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- YugpotMay 21, 2023AspirantC7800, the first place I looked was the manual but it really doesn’t show where the on off button is and it’s not labeled. this is the first time it’s happened. I’ve had it for a long time and I went to reset the connection and apparently I hit the on off button by mistake and I can’t figure out how to cut it back on.
- plemansMay 21, 2023Guru - Experienced User
page 10 in the manual literally has a photo pointing to the on/off button with a label?
