gigles13
Jun 24, 2021Guide
One upstream channel locked - amber light
Hi, I have a Netgear CM600 for the last 2 years along with the Orbi Mesh system. I haven't had any problems except the last 2 months or so. I updated the firmware on the Orbi Mesh system and I st...
- Jun 24, 2021
There ya go. Looks like it's working now. Please mark your thread as solved.
Enjoy. :smileywink:
gigles13
Jun 24, 2021Guide
There are no splitters.
Powered off and on already.
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 609000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv4 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 6 | 609000000 Hz | -16.1 dBmV | 35.0 dB | 0 | 0 |
| 2 | Locked | QAM256 | 5 | 603000000 Hz | -16.0 dBmV | 35.1 dB | 2 | 0 |
| 3 | Locked | QAM256 | 7 | 615000000 Hz | -15.3 dBmV | 35.4 dB | 2 | 0 |
| 4 | Locked | QAM256 | 8 | 621000000 Hz | -14.5 dBmV | 35.9 dB | 2 | 0 |
| 5 | Locked | QAM256 | 9 | 627000000 Hz | -14.7 dBmV | 35.7 dB | 1 | 0 |
| 6 | Locked | QAM256 | 10 | 633000000 Hz | -15.2 dBmV | 35.5 dB | 1 | 0 |
| 7 | Locked | QAM256 | 11 | 639000000 Hz | -15.1 dBmV | 35.5 dB | 4 | 0 |
| 8 | Locked | QAM256 | 12 | 645000000 Hz | -13.6 dBmV | 36.3 dB | 1 | 0 |
| 9 | Locked | QAM256 | 13 | 651000000 Hz | -13.4 dBmV | 36.4 dB | 5 | 0 |
| 10 | Locked | QAM256 | 14 | 657000000 Hz | -13.3 dBmV | 36.5 dB | 1 | 0 |
| 11 | Locked | QAM256 | 15 | 663000000 Hz | -13.2 dBmV | 36.6 dB | 2 | 0 |
| 12 | Locked | QAM256 | 16 | 669000000 Hz | -12.5 dBmV | 36.9 dB | 8 | 0 |
| 13 | Locked | QAM256 | 17 | 675000000 Hz | -10.9 dBmV | 37.1 dB | 2 | 0 |
| 14 | Locked | QAM256 | 18 | 681000000 Hz | -10.9 dBmV | 37.2 dB | 1 | 0 |
| 15 | Locked | QAM256 | 19 | 687000000 Hz | -11.6 dBmV | 36.8 dB | 4 | 0 |
| 16 | Locked | QAM256 | 20 | 693000000 Hz | -11.7 dBmV | 36.8 dB | 6 | 0 |
| 17 | Locked | QAM256 | 21 | 699000000 Hz | -11.3 dBmV | 37.8 dB | 0 | 0 |
| 18 | Locked | QAM256 | 22 | 705000000 Hz | -10.7 dBmV | 38.0 dB | 0 | 0 |
| 19 | Locked | QAM256 | 23 | 711000000 Hz | -11.2 dBmV | 37.8 dB | 0 | 0 |
| 20 | Locked | QAM256 | 24 | 717000000 Hz | -12.0 dBmV | 37.5 dB | 0 | 0 |
| 21 | Locked | QAM256 | 25 | 723000000 Hz | -12.2 dBmV | 37.1 dB | 0 | 0 |
| 22 | Locked | QAM256 | 26 | 729000000 Hz | -12.2 dBmV | 36.9 dB | 0 | 0 |
| 23 | Locked | QAM256 | 27 | 735000000 Hz | -12.1 dBmV | 36.2 dB | 0 | 0 |
| 24 | Locked | QAM256 | 28 | 741000000 Hz | -12.9 dBmV | 35.6 dB | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 49 | 5120 Ksym/sec | 36800000 Hz | 57.0 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 3 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 4 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
gigles13
Jun 24, 2021Guide
I spoke to optimum and they did something to my modem. I now have 4 channels bonded for upstream.
| Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Downstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Upstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
