I spoke to optimum and they did something to my modem. I now have 4 channels bonded for upstream.
| Startup Procedure |
| Procedure | Status | Comment |  | Acquire Downstream Channel | 609000000 Hz | Locked |  | Connectivity State | OK | Operational |  | Boot State | OK | Operational |  | Security | Enable | BPI+ |  | IP Provisioning Mode | Honor MDD | IPv4 only |
| <tabindex=-1>Downstream Bonded Channels</tabindex=-1> |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |  | 1 | Locked | QAM256 | 6 | 609000000 Hz | -16.6 dBmV | 34.7 dB | 0 | 0 |  | 2 | Locked | QAM256 | 5 | 603000000 Hz | -16.5 dBmV | 34.8 dB | 0 | 0 |  | 3 | Locked | QAM256 | 7 | 615000000 Hz | -15.8 dBmV | 35.2 dB | 0 | 0 |  | 4 | Locked | QAM256 | 8 | 621000000 Hz | -15.0 dBmV | 35.6 dB | 0 | 0 |  | 5 | Locked | QAM256 | 9 | 627000000 Hz | -15.2 dBmV | 35.4 dB | 0 | 0 |  | 6 | Locked | QAM256 | 10 | 633000000 Hz | -15.6 dBmV | 35.3 dB | 0 | 0 |  | 7 | Locked | QAM256 | 11 | 639000000 Hz | -15.6 dBmV | 35.2 dB | 0 | 0 |  | 8 | Locked | QAM256 | 12 | 645000000 Hz | -14.1 dBmV | 36.1 dB | 1 | 0 |  | 9 | Locked | QAM256 | 13 | 651000000 Hz | -13.9 dBmV | 36.2 dB | 0 | 0 |  | 10 | Locked | QAM256 | 14 | 657000000 Hz | -13.7 dBmV | 36.3 dB | 0 | 0 |  | 11 | Locked | QAM256 | 15 | 663000000 Hz | -13.6 dBmV | 36.4 dB | 1 | 0 |  | 12 | Locked | QAM256 | 16 | 669000000 Hz | -12.9 dBmV | 36.7 dB | 1 | 0 |  | 13 | Locked | QAM256 | 17 | 675000000 Hz | -11.3 dBmV | 36.9 dB | 1 | 0 |  | 14 | Locked | QAM256 | 18 | 681000000 Hz | -11.3 dBmV | 37.1 dB | 0 | 0 |  | 15 | Locked | QAM256 | 19 | 687000000 Hz | -12.0 dBmV | 36.6 dB | 1 | 0 |  | 16 | Locked | QAM256 | 20 | 693000000 Hz | -12.1 dBmV | 36.6 dB | 0 | 0 |  | 17 | Locked | QAM256 | 21 | 699000000 Hz | -11.6 dBmV | 37.5 dB | 0 | 0 |  | 18 | Locked | QAM256 | 22 | 705000000 Hz | -11.0 dBmV | 37.9 dB | 0 | 0 |  | 19 | Locked | QAM256 | 23 | 711000000 Hz | -11.6 dBmV | 37.7 dB | 0 | 0 |  | 20 | Locked | QAM256 | 24 | 717000000 Hz | -12.4 dBmV | 37.2 dB | 0 | 0 |  | 21 | Locked | QAM256 | 25 | 723000000 Hz | -12.6 dBmV | 37.0 dB | 0 | 0 |  | 22 | Locked | QAM256 | 26 | 729000000 Hz | -12.6 dBmV | 37.0 dB | 0 | 0 |  | 23 | Locked | QAM256 | 27 | 735000000 Hz | -12.5 dBmV | 35.9 dB | 0 | 0 |  | 24 | Locked | QAM256 | 28 | 741000000 Hz | -13.3 dBmV | 35.7 dB | 0 | 0 |
| <tabindex=-1>Upstream Bonded Channels</tabindex=-1> |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |  | 1 | Locked | ATDMA | 49 | 5120 Ksym/sec | 36800000 Hz | 51.0 dBmV |  | 2 | Locked | ATDMA | 52 | 5120 Ksym/sec | 17600000 Hz | 51.0 dBmV |  | 3 | Locked | ATDMA | 51 | 5120 Ksym/sec | 24000000 Hz | 51.0 dBmV |  | 4 | Locked | ATDMA | 50 | 5120 Ksym/sec | 30400000 Hz | 51.0 dBmV |  | 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |  | 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |  | 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |  | 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
