frank95987
Apr 29, 2020Aspirant
One year factory warranty not useful when gated by 90-day phone support
My ISP claims that my netgear cable modem in faulty. I purchased it less than a year ago so I'm still covered under the factory warrenty. However, when I called support today they told me that my 90-...
- May 07, 2020I ended up buying a different modem (different brand). The purchase price was less than the lowest cost phone support offered by Netgear đ. I checked with their customer phone support before doing so. They will fully support their product via phone and other means for the full term of their factory warranty. Good bye Netgear, while your policy might have saved you a bit of money in the short term, it possibly could cost you more in the long run. There's absolutely no way I would every purchase a Netgear product for home use again and I'm now likely biased against your brand such that it could influence my behavior when provisioning networking equipment at work.
Apr 29, 2020Guru - Experienced User
- frank95987May 07, 2020AspirantI ended up buying a different modem (different brand). The purchase price was less than the lowest cost phone support offered by Netgear đ. I checked with their customer phone support before doing so. They will fully support their product via phone and other means for the full term of their factory warranty. Good bye Netgear, while your policy might have saved you a bit of money in the short term, it possibly could cost you more in the long run. There's absolutely no way I would every purchase a Netgear product for home use again and I'm now likely biased against your brand such that it could influence my behavior when provisioning networking equipment at work.
