rhosue21
Feb 22, 2022Aspirant
Only getting ~400Mbps down on 1.2Gbps service with CM1150V Cable Modem and Nighthawk AC2600 (R7450)
I can't figure this out. I have a CM1150V Cable Modem and Nighthawk AC2600 / R7450 Wi-Fi Router and am only able to get a maximum of just over 400Mbps download speed. I have confirmed this using the ...
Feb 24, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
rhosue21
Feb 28, 2022Aspirant
Here is the screenshot of my status page.
- FURRYe38Feb 28, 2022Guru - Experienced User
Power levels look ok.
A few Correctables however nothing to bother the modem I believe. I would check all wires and coax jack connections to make sure they are correctly seated and fitted well to the jacks.
Check for any line splitters as well.
What the Events Logs show? Please post that capture as well.
- rhosue21Feb 28, 2022Aspirant
Here is my latest event log.
Couple of criticle which the ISP should take a look into.
Again, all this depends on good signal from the ISP street box or line pole up to you home and to the modem. If anything is off inbetween, could cause problems here.
Other option would be to rent for a short period of time, one of there modems and see if you notice similar problems or not. If you do, then you'll know.
