rhosue21
Feb 22, 2022Aspirant
Only getting ~400Mbps down on 1.2Gbps service with CM1150V Cable Modem and Nighthawk AC2600 (R7450)
I can't figure this out. I have a CM1150V Cable Modem and Nighthawk AC2600 / R7450 Wi-Fi Router and am only able to get a maximum of just over 400Mbps download speed. I have confirmed this using the ...
rhosue21
Feb 28, 2022Aspirant
Here is the screenshot of my status page.
Feb 28, 2022Guru - Experienced User
Power levels look ok.
A few Correctables however nothing to bother the modem I believe. I would check all wires and coax jack connections to make sure they are correctly seated and fitted well to the jacks.
Check for any line splitters as well.
What the Events Logs show? Please post that capture as well.
