Doug_K's avatar
Doug_K
Follower
Nov 22, 2019
Ooma Telco and Nighthawk CM2100
Guys-
I know this is the wrong board to post in.
NetGear web site didn't have board option for direct questions regarding the cable modem itself and its LAN Ports.
Here goes....
My Nighthawk CM1200 is a cable modem with four LAN Ports.
Learned not to use LAN Port 2 since I have Ethernet Port Aggregation disabled.
Plugged my Ooma Telco into LAN Port 4.
My Problem:
Ooma not able to recognize Internet access. Just sits and blinks.
Tried all the various turn on / turn off / reset combinations - no luck.
Any insights / suggestions?
Ooma worked fine with my Arris Modem.
Swapped out the Arris, put the Nighthawk on-line, and now I'm stuck.
