cuasitos
Sep 04, 2017Aspirant
open ports for amule
hi i am trying t open ports for amule in mac but the config page sayme that The specified port(s) are being used by other configurations. Please check your configurations of USB Readyshare, Remote M...
antinode
Sep 05, 2017Guru
> [...] i am trying t open ports for amule in mac [...]
Which ports? How, exactly? As usual, describing actual actions and
their actual results can be more helpful than vague descriptions or
interpretations.
Is this "amule" the one described at http://www.amule.org/ ? Which
version?
> [...] Please check your configurations of [...]
What are all those data?
- cuasitosSep 05, 2017AspirantOk the software is the one you put the address amule.org
The port are tcp 4662 and udp 4672
I went to advance config port fowarding add a service
I put the name the tcp option external port the internal port numbers and apply and sayme another option are using that port
