mattrollo
Sep 02, 2017Aspirant
open tcp ports ac1600 for use with tivo moca
How can I open several TCP ports to use my TiVo Bolt with MoCa
TheEther
Sep 02, 2017Guru
Unless you are trying to access your Tivo remotely, you should not need to open any ports. The router by default does not block any ports in the outbound direction.
- mattrolloSep 03, 2017AspirantI actually had to open 9 ports but figured out how to do it using the Netgear genie under advanced while I was on hold with customer service and everything is perfect. I have to give props to Netgear for genie.
- TheEtherSep 03, 2017GuruCongrats on getting it working.
I'm curious to know which ports you had to open? According to Tivo's own support page, you do not need to open any inbound ports:
https://support.tivo.com/articles/Troubleshooting/Which-Network-Ports-and-IP-Addresses-Need-to-be-Open-When-Using-my-TiVo-DVR- mattrolloSep 03, 2017AspirantI remember a 8080, 8081, a 5227? Not sure but the TiVo had them all listed and it was easier than I thought. Never even got a chance to customer support.
