mattrollo
Sep 02, 2017Aspirant
open tcp ports ac1600 for use with tivo moca
How can I open several TCP ports to use my TiVo Bolt with MoCa
TheEther
Sep 02, 2017Guru
Unless you are trying to access your Tivo remotely, you should not need to open any ports. The router by default does not block any ports in the outbound direction.
mattrollo
Sep 03, 2017Aspirant
I actually had to open 9 ports but figured out how to do it using the Netgear genie under advanced while I was on hold with customer service and everything is perfect. I have to give props to Netgear for genie.
