Picpat
Feb 28, 2020Aspirant
open up a closed port R6400
I have a R6400 router that is showing closed port's 80, 9000.
these ports run my security system Lorex. LH161200. I am able to view the cams from with the house. As soon as I go more then 100 ' I loose the connection.
Also, the connection goes in and out while at the house.
I have tried multi times to try and open these ports without success.
I have read chapter 13 pg 161 of the netgear manual and followed the instructions.
can someone please help be fix this?
Everytime I type in "www.yougetsignal" and test for open ports these come back as closed
thank you all for you time
Pat
1 Reply
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-generalGood Luck.
