Alanbear
Dec 23, 2017Follower
Opening a port / port fowarding
my nest thermostats recently cut off and the nest tech support said i needed to open a port on my router for devices to prefent them from being shut off.
I have been watching you tube videos and scanning forums but have yet to find a comprehensive way of accessing these devices in my router and moving them to an open port.
I can find the IP address that the nest currently has from my router and go to the port forwarding screen in the setup of the router, but I dont understand how I tell the router to port that device specifically or open the port for the device with the Ip address it has assigned.
when i get to the add custom service tab there are a lot of values that need to be entered and Im at a loss of the values that need to be entered.
So I have devices that need to have an open port and unrestricted access. Is there an easy to digest tutorial or instruction on how to do this?
Thank you in advance.
1 Reply
- I'm not sure why the Nest tech told you that. You do not need to open any ports. My Nest works fine without any open ports.
Can you explain a bit further what's going on? What do you mean by cut off? Are they not connecting to your Wi-Fi or are they not connecting to the Internet?
