wmpooler
Feb 23, 2017Tutor
Opening Nat types for PS4 2017
I am trying to open my NAT type but I dont even have the option to change the type. I have followed the instructions but I dont have the option to change it. I followed the instructions @ https://k...
wmpooler
Feb 24, 2017Tutor
Does mine have the option? I tried all of the mentioned steps, none worked.
- ElaineMFeb 27, 2017NETGEAR Employee Retired
If you do not see it then yours doesn't have it.
If your NAT is still strict verify if you can get it working without a router.You might have a double NAT issue.
