wmpooler
Feb 23, 2017Tutor
Opening Nat types for PS4 2017
I am trying to open my NAT type but I dont even have the option to change the type. I have followed the instructions but I dont have the option to change it. I followed the instructions @ https://k...
wmpooler
Feb 24, 2017Tutor
Does mine have the option? I tried all of the mentioned steps, none worked.
ElaineM
Feb 27, 2017NETGEAR Employee Retired
If you do not see it then yours doesn't have it.
If your NAT is still strict verify if you can get it working without a router.
You might have a double NAT issue.
