wmpooler
Feb 23, 2017Tutor
Opening Nat types for PS4 2017
I am trying to open my NAT type but I dont even have the option to change the type. I have followed the instructions but I dont have the option to change it. I followed the instructions @ https://k...
wmpooler
Feb 28, 2017Tutor
I followed the instructions previously and the games work but some features are limited due to the Nat Type be set as strict. I connect using the wired method.
ElaineM
Mar 01, 2017NETGEAR Employee Retired
Did you try playing without using the router?
What's the brand and model of your modem?
