wmpooler
Feb 23, 2017Tutor
Opening Nat types for PS4 2017
I am trying to open my NAT type but I dont even have the option to change the type. I have followed the instructions but I dont have the option to change it. I followed the instructions @ https://k...
wmpooler
Mar 01, 2017Tutor
The game works, I just can't join other players lobby due to the strict Nat type
ElaineM
Mar 01, 2017NETGEAR Employee Retired
Right, I understand that but I want to see if it's the same if you'll play it without a router.
As far as the router is concerned, you can do Port Forwarding or try use DMZ.
