wmpooler
Feb 23, 2017Tutor
Opening Nat types for PS4 2017
I am trying to open my NAT type but I dont even have the option to change the type. I have followed the instructions but I dont have the option to change it. I followed the instructions @ https://k...
wmpooler
Mar 03, 2017Tutor
I guess I will have to play around with the dmz again, nothing else is working and this is unresolved.
TheEther
Mar 03, 2017Guru
Does your modem have a router built into it? If yes, then you have double NAT and no amount of port forwarding on the Netgear is going to work. You either need to enable bridge mode on the modem or convert your Netgear into an Access Point. This will eliminate double NAT. Then you can focus on setting up port forwarding on whichever device is functioning as a router.
