chickenqv1
Sep 29, 2016Aspirant
Opening Port for a Program/Port Forwarding
Hi, I have a Netgear C3000-100NAS I opened a certain port in my advanced settings. I went to a third-party website to check if my port was opened. It said it was closed still. I would like some ...
- Oct 15, 2016
Hi I fixed it. I had to set up a static IP address on my PC. I used this guide:
https://portforward.com/networking/static-win7.htm
Thank you
chickenqv1
Oct 03, 2016Aspirant
Hey Darren,
I am trying to open port UDP 34987
DarrenM
Oct 05, 2016Sr. NETGEAR Moderator
Hello chickenqv1
Have you made sure to use address reservation on the PC you are trying to port forward?
DarrenM
- chickenqv1Oct 07, 2016Aspirant
Hey Darren, do you mean use a static ip?
- DarrenMOct 10, 2016Sr. NETGEAR Moderator
Hello chickenqv1
Here is what I am talking about.
http://kb.netgear.com/app/answers/detail/a_id/25722?cid=wmt_netgear_organic
DarrenM
- chickenqv1Oct 13, 2016Aspirant
Hi Darren,
That solution did not work for me.
I used the ipv4 ip address found under the ipconfig /all in the command prompt and copied the mac address. Restarted my computer. I tried to force a DHCP release and renew but the command prompt didn't allow me to do it.
Do I open a port under the "port forwarding" option or "port triggering" option. I used "port forwarding" I do not know what "port triggering" does so I don't want to mess with it.
- DarrenMOct 13, 2016Sr. NETGEAR Moderator
Port forwarding is what you want.
DarrenM
