getjetdat
Nov 12, 2021Follower
Opening UDP ports 5060 thru 5070
How do I open UDP ports 5060 thru 5070 on my C6900 router/modem? How can I check that UDP ports 5060 thru 5070 are already open? Model: C6900|High Speed Cable Modem Router
Nov 12, 2021Guru - Experienced User
I would review the user manual for this information. Be sure to disable uPnP if you configure port fowarding on the modem.
Maybe some KB articles can be of help:
