j4x4's avatar
j4x4
OpenVPN 2.5.4 Configuration Problems on Orbi CBR750
Hello,
I am running an Orbi CBR750, firmware V4.6.3.6_2.0.48 with OpenVPN 2.5.4 installed on a Windows 10 machine. When I run OpenVPN, I get these error messages:
Wed Oct 20 20:33:30 2021 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
Wed Oct 20 20:33:30 2021 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-128-CBC' to --data-ciphers or change --cipher 'AES-128-CBC' to --data-ciphers-fallback 'AES-128-CBC' to silence this warning.
Wed Oct 20 20:33:30 2021 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Wed Oct 20 20:33:32 2021 OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Wed Oct 20 20:33:32 2021 OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.1.0
Wed Oct 20 20:33:37 2021 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
I am trying to install certificate-based authentication for OpenVPN, and then have every device on my network protected without having to install the VPN client on each and every device.
I would be very grateful for any help the community can offer.
1 Reply
