StevenMat
Dec 04, 2024Follower
Orbi CBK750 indicator lights not working
The Orbi is still working. BUT, all the indicator lights on the front of the device are off. It started with just the Online LED went off. Then the Upstream LED went out followed a few weeks later...
CrimpOn
Dec 04, 2024Guru - Experienced User
StevenMat wrote:
Now not even the Power LED is on. But the device is running just fine;
This is confusing. The CBR750 User Manual, page 102 appears to say that it is normal for ALL of those LED's to go off.
https://www.downloads.netgear.com/files/GDC/CBK752/CBK750_UM_EN.pdf
Front facing LEDs are modem indications for the modem side of the unit. These should ON always. The bottom LED nearest the footing is the Orbi router LED, this one should be OFF when working normally. Back Power LED should be alwasy ON as GREEN.
- CrimpOnDec 04, 2024Guru - Experienced User
I just love Netgear User Manuals.
