mmalone33
Nov 04, 2024Aspirant
ORBI CBR 750 loses internet connect then reboots
My CBR 750 keeps having connection issues then reboots after losing internet connection. Usually happens once or twice a day. I have read a ton of forums on problems with these having the same extrac...
Nov 04, 2024Guru - Experienced User
Do the front LEDs show anything or bottom LED turn on PINK when this happens?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- mmalone33Nov 04, 2024Aspirant
Firmware Version V4.6.14.4_2.3.12
The normal reboot pattern, flashing white light on the bottom as the front LED's flash then remain solid.
- FURRYe38Nov 04, 2024Guru - Experienced User
Does the bottom LED turn BLUE or just blink WHITE then eventually turn OFF fully?
Well I have a "rebooter" connected to it in case their is a disconnect from the internet. I have it set at 60 seconds then it'll reboot the Orbi. I've been in the room where I notice a drop in connection and then it gets reset from the rebooter. Most of the time it connects in one reboot, sometimes it takes a couple reboots.
No blue light, normally just pulsing white light.
