mmalone33
Nov 04, 2024Aspirant
ORBI CBR 750 loses internet connect then reboots
My CBR 750 keeps having connection issues then reboots after losing internet connection. Usually happens once or twice a day. I have read a ton of forums on problems with these having the same extrac...
mmalone33
Well I have a "rebooter" connected to it in case their is a disconnect from the internet. I have it set at 60 seconds then it'll reboot the Orbi. I've been in the room where I notice a drop in connection and then it gets reset from the rebooter. Most of the time it connects in one reboot, sometimes it takes a couple reboots.
No blue light, normally just pulsing white light.
Nov 04, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log data page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
