jobe2433
May 29, 2019Aspirant
Orbi CBR40 help
Hello, after a power outage 2 days ago I’ve been unable to get my internet back up and running either WiFi or wired. All lights on Orbi are blue and Comcast is even able to restart the modem from thei...
May 29, 2019Guru - Experienced User
Please post here in this forum:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
jobe2433 wrote:
Hello, after a power outage 2 days ago I’ve been unable to get my internet back up and running either WiFi or wired. All lights on Orbi are blue and Comcast is even able to restart the modem from their end. They are saying everything is fine: is there anything I can do to fix this? I have tried restarting and resetting both the modem and satellite . Any help would be very much appreciated
- jobe2433May 29, 2019AspirantThank you . I am unable to get wired connections as well. It just seems like there is a block somewhere . I will try the settings that you suggest . My firmware is 2 . 3 .0 .10. I will update in a few
