waynelai
Jun 27, 2024Aspirant
Orbi CBR750 downstream LED is off
Hi all, I just came back from a 2 week trip and noticed that the Orbi CBR750 LED is constantly off. The modem seems to be working but slow. I saw the followings in the event log. Any idea what's ...
Jun 27, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
- waynelaiJun 27, 2024Aspirant
It's running the latest firmware V4.6.14.4. Attached is the cable connection information. Looks like downstream isn't locked.
- FURRYe38Jun 27, 2024Guru - Experienced User
Power levels are on the low side but with in spec. Could maybe up the power just a bit.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Correctables and Un-correctables are zeros so thats good.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/- waynelaiJun 27, 2024Aspirant
Thanks! I'll get a Xfinity tech to come over and check.
