ron352
Nov 17, 2024Aspirant
Orbi CBR750 drop connection wan side
Recently a few weeks now I noticed internet connection drops. I have Spectrum cable to Orbi CBR750 Modem/Router. Not sure if there was a firmware update but it is currently V4.6.14.4_2.3.12 I have t...
Nov 18, 2024Guru - Experienced User
Wow, Might ask the ISP to help you turn down the power a bit more then.
Has a factory reset and setup from scratch been performed?
The ISP needs to check the events log and resolve issues seen there. Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
ron352
Nov 18, 2024Aspirant
Yesterday I hit the factory reset on the Orbi and set it back up.
This morning it went out at around 7:50 am I had to pull the power and plug it back in.
I just ordered a -3DB attinuator will try when it comes.
Maybe the 6DB one was not enough but it worked fine in there till recently
- FURRYe38Nov 18, 2024Guru - Experienced User
