ron352
Nov 17, 2024Aspirant
Orbi CBR750 drop connection wan side
Recently a few weeks now I noticed internet connection drops. I have Spectrum cable to Orbi CBR750 Modem/Router. Not sure if there was a firmware update but it is currently V4.6.14.4_2.3.12 I have t...
Nov 22, 2024Guru - Experienced User
There we go.
Looks good now.
If you get the -10db, then that one will be all that you need. Won't need the others in line as it would drop the power too much. Levels are good here with the two inline that you have. Your right in the middle of the spec and thats good.
ron352
Nov 22, 2024Aspirant
