ron352
Nov 17, 2024Aspirant
Orbi CBR750 drop connection wan side
Recently a few weeks now I noticed internet connection drops. I have Spectrum cable to Orbi CBR750 Modem/Router. Not sure if there was a firmware update but it is currently V4.6.14.4_2.3.12 I have t...
Nov 22, 2024Guru - Experienced User
If the ISP modem is a 1Gb or lessor modem then ya. Most speeds you'll see is around 900Mpbs on typical 1Gb modems along with a 1Gb router. Anything beyond that, you'll need a modem and router that has 2.5Gb or higher WAN and LAN ports.
Possible that the ISP modem may or may not show same event log details. Not sure if those are standard across branded modems or not. I presume they should be.
ron352
Nov 22, 2024Aspirant
The lady said she will be able to see critical errors and stuff with their modem. I just bought a TP-Link router good for 1.8 gigs. She said her equipment would not allow her to activate the old modem since it was not rated gigabit speed. So all set with the router matter of time when they deliver the new modem.
