ron352
Nov 17, 2024Aspirant
Orbi CBR750 drop connection wan side
Recently a few weeks now I noticed internet connection drops. I have Spectrum cable to Orbi CBR750 Modem/Router. Not sure if there was a firmware update but it is currently V4.6.14.4_2.3.12 I have t...
ron352
Nov 25, 2024Aspirant
I had already tried using the Orbi Modem/Router with the Spectrum Modem and it did not seem to work.
That is why I bought the TP Link
Nov 26, 2024Guru - Experienced User
For the faux AP mode on the CBR, you'll need the TP Link router.
- ron352Nov 26, 2024Aspirant
Ok thanks. Might try it but don't need it. I wish Spectrum would of just let me send the log I had on the Orbi on critical errors it would of made things so much easier.
- FURRYe38Nov 26, 2024Guru - Experienced User
Should send it anyways. Seems like the Event logs read out would be same as other branded modems since the modem side is all DOCSIS information and diagnostics.
Maybe at some point put the CBR back ON and check it. Other wise, good luck.
