Steven423
Dec 23, 2022Aspirant
Orbi RBS750 satellite won't sync to CBR750 modem/router
Hello, so I had bought this package from Best Buy earlier this year (CBR750 modem/router with RBS750 satellite). It had been working great till maybe about a couple months ago when the satellite no l...
- Dec 23, 2022
The RBS FW needs to be downgraded to what you see on the CBK750 web download site.
Dec 23, 2022Guru - Experienced User
What version of FW did you load on the CBR and RBS?
Steven423
RBS750 would be newest version which is:
Version 4.6.14.3
CBS750 newest version would be:
Version 4.6.5.8
- FURRYe38Dec 23, 2022Guru - Experienced User
- Steven423Dec 23, 2022Aspirant
Ahh.. I see now that they made a whole separate support page for the package which they list as (CBK750) compared to what I did, which was look at the separate support pages for each model (CBR750) and (RBS750). I don't know why they felt the need to do that.. I also don't know why it's necessary to downgrade firmware to get products working when firmware updates are generally created to address security issues. I hope Netgear gets this resolved quickly..
I will attempt the downgrade to the listed version when I'm able, and report back if this was the solution. Thanks!
- FURRYe38Jan 06, 2023Guru - Experienced User
Any progress on this?
