EclipseGSX23
Sep 03, 2020Aspirant
Orbi WiFi 6 System (RBK853) AX6000 And Modem cm2000, 1200 or 1000
Looking to get into the Orbi WiFi 6 System (RBK853) AX6000. Also a good modem to go with it. So the question is below what's better to work with it. I need a modem that’s state of the art but ...
Sep 04, 2020Guru - Experienced User
the CM2000 has only 1 ethernet port but its capable of 2.5g. so is the RBK853
so you have the capability of >1gig speeds from your isp. If its compatible with your isp's service.
I'd recommend either the CM2000, the CM1100, or the CM1000 (if compatible)
CM2000: capable of 2.5gig
CM1100: capable of port aggregation for >1gig speeds
CM1000: capable of 1 gig speeds.
- EclipseGSX23Sep 04, 2020Aspirant
Hey, thanks for the reply. After reading further, I saw on the mesh system it recommended the cm1200. Your opinion on that one??
- plemansSep 04, 2020Guru - Experienced User
Unless you have an ISP that allows multiple public ip address (most don't) then its kind of pointless.
- EclipseGSX23Sep 05, 2020Aspirant
Ok, thx very much. Wish the netgear guy would have told me that. I thought that and I'm like maybe in the future. We do have a family business but do everything at home and never thought the need of a second. Hopefully they'll let me switch the order. Ordered the meet system and the 1200. Shame they said do the 1200 instead of the 1000. Thanks man!!
