EclipseGSX23
Sep 03, 2020Aspirant
Orbi WiFi 6 System (RBK853) AX6000 And Modem cm2000, 1200 or 1000
Looking to get into the Orbi WiFi 6 System (RBK853) AX6000. Also a good modem to go with it. So the question is below what's better to work with it. I need a modem that’s state of the art but ...
EclipseGSX23
Sep 04, 2020Aspirant
Hey, thanks for the reply. After reading further, I saw on the mesh system it recommended the cm1200. Your opinion on that one??
Sep 04, 2020Guru - Experienced User
Unless you have an ISP that allows multiple public ip address (most don't) then its kind of pointless.
- EclipseGSX23Sep 05, 2020Aspirant
Ok, thx very much. Wish the netgear guy would have told me that. I thought that and I'm like maybe in the future. We do have a family business but do everything at home and never thought the need of a second. Hopefully they'll let me switch the order. Ordered the meet system and the 1200. Shame they said do the 1200 instead of the 1000. Thanks man!!
- plemansSep 06, 2020Guru - Experienced User
Other than costing a little extra, you're not out anything. Its based on the same chipset as the CM1000.
And you never know, maybe your isp will allow mulitple public ip addresses. Or you'll end up switching to a business class line for the business. Usually those allow the multiple public ip addresses.
- FURRYe38Sep 07, 2020Guru - Experienced User
Who is your ISP? I know for my ISP, I have have multiple WAN IPs on my 1100, 1200, 2000 and CAX80. :smileyvery-happy: Sparklight.
