lstone19's avatar
May 13, 2020
Overloaded C3000-100NAS?
Problem: Two or three times a day for short periods of usually no more than 15 minutes, we are unable to connect to the Internet (Comcast). When it happens, all devices on the network are affected. I...
  • lstone19's avatar
    lstone19
    May 21, 2020
    It's been a week since putting the C3000 in bridge mode and making my new WAC124 the router and no recurrences of the outages I've been seeing. Also five days since replacing the powered splitter with an unpowered one which has brought the power levels down to the range plemans said it should be (seeing about 5 dBmV on each download channel).
    My conclusion, largely from another forum where I posted the issue, is that C3000 has too small a NAT table which was becoming exhausted under high demand. It would appear the WAC124 has a larger one (unfortunately, I could not find spec sheets for either listing the size).
    I'm considering this issue resolved.
