lstone19
May 13, 2020Tutor
Overloaded C3000-100NAS?
Problem: Two or three times a day for short periods of usually no more than 15 minutes, we are unable to connect to the Internet (Comcast). When it happens, all devices on the network are affected. I...
- May 21, 2020
It's been a week since putting the C3000 in bridge mode and making my new WAC124 the router and no recurrences of the outages I've been seeing. Also five days since replacing the powered splitter with an unpowered one which has brought the power levels down to the range plemans said it should be (seeing about 5 dBmV on each download channel).
My conclusion, largely from another forum where I posted the issue, is that C3000 has too small a NAT table which was becoming exhausted under high demand. It would appear the WAC124 has a larger one (unfortunately, I could not find spec sheets for either listing the size).
I'm considering this issue resolved.
May 13, 2020Guru - Experienced User
power levels are a bit high. Optimal is between -7dbmv and 7dbmv. You're in the upper range of stable. But not seeing errors.
Maybe the power level is going up a bit at times and causing issues. I'd try an attenuator or you can try a splitter in line to see if it drops the level and keeps it more stable.
lstone19
May 13, 2020Tutor
Interesting. I have a powered splitter to split the cable to the modem and to a TiVo. I'll try replacing it with a non-powered splitter.
Why a powered splitter? Well, while today the cable only serves those two (upstairs TVs servers by TiVo minis via Ethernet), when the cable had to serve upstairs TVs, there were problems due to the long run (length of the house, up to the attic, another splitter, and then back to the master bedroom - probably over 100 feet). Putting a powered splitter both for the run to the attic and another in the attic cleared up the TV reception problems.
- plemansMay 13, 2020Guru - Experienced User
try this.
get a double splitter.
Send one leg to the modem. Send the other to the powered splitter. and then feed the rest of the home.
You don't want a powered splitter prior to the modem.
- lstone19May 14, 2020Tutor
Just an update to let you know I'm not ignoring the suggestion. I found the unpowered splitters I had were not suitable for today's needs so am working on getting a new one. In the meantime, based on a response in another (non-Netgear) forum where I posted this, I have gone ahead and reconfigured to put the C3000 in bridge mode and make the WAC124 the router. I want to give it a few days like that before making another change.
While getting the power levels in spec is certainly important, I don't think it's the problem. I'm fairly convinced that the problem is only with new TCP connections and not with UDP or existing TCP connections and from my days doing system administration on various computer systems, most "existing works, new fails" type problems are resource exhaustion issues (I've worked on systems where if you saw something hung in a Resource Wait state, your next step was to start asking when you could reboot the system). If the power levels were the problem, I'd expect everything to fail, not just new.
- plemansMay 14, 2020Guru - Experienced UserYou're welcome to try whatever you think is going to work.
I would try and get the powered splitter feeding the modem out of there. It can give you to high of numbers as well as cause issues on the upload.
