dangermuffin
Oct 31, 2019Aspirant
Packet loss cm1200
So I've been getting really bad packet loss, after using ping plotter from my PC to trace the issue, I believe I've narrowed it down to the CM1200 modem. This is what my setup looks like.. modem...
Nov 01, 2019Guru - Experienced User
If you're concerned its the modem, you should be posting in the modem forum.
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
It's more focused on the modem.
make sure when you repost there to include a screen snip of your modem connections page with upload/download. Also include the logs.
What speeds do you pay for?
What speeds do you get?
I'd recommend removing any splitters, amplifiers, 90 degree elbows, kinked coax, bad connectors, old coax, or extended runs. also check for loose connections.
Another thing to check is dslreports.com has some nice tools for modem testing you can try.
dangermuffin
Nov 01, 2019Aspirant
Will create a post there! thanks.
We pay for 300mbps and get between that and 100. It fluctuates often. The only 'splitter' we have is ethernet switch but I used it at my previous house with no issues. Also ran a test with my PC plugged directly into modem and still had issues. I'll try dsl reports tools for modems too!
