dangermuffin
Nov 01, 2019Aspirant
Packet Loss with CM1200
So I've been getting really bad packet loss, after using ping plotter from my PC to trace the issue, I believe I've narrowed it down to the CM1200 modem. This is what my setup looks like.. modem...
Nov 01, 2019Guru - Experienced User
Thanks for posting in the correct forum! :)
did you get a screen snip of your connections page? and logs?
You also put in the other post there's a switch in line (when I asked about splitters). It should go CM1200----router----swtich. Is this how you have it?
dangermuffin
I didn't get a snip of the connections page or logs. I logged into my modem last night and didn't see anything like that. I'm at work and could attempt again in a few hours when I"m home.
and correct, that's how I have my setup modem > router > switch
Here's a screen shot of my PC plugged directly into the modem. For some reason it's appearing as that 10.xxx.x.x IP address but when I ran an IP config when plugged in it came back as a different IP.
Also wanted to point out that the response time with the modem according to ping plotter seems higher than it should be, even when plugged in directly!
Thanks!
- plemansNov 01, 2019Guru - Experienced User
try this ping test. I've never used the you you're showing
- dangermuffinNov 01, 2019Aspirant
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 11 843000000 Hz 2.7 dBmV 41.1 dB 1 0 2 Locked QAM256 1 783000000 Hz 0.6 dBmV 40.8 dB 23 0 3 Locked QAM256 2 789000000 Hz 0.6 dBmV 40.8 dB 16 0 4 Locked QAM256 3 795000000 Hz 0.8 dBmV 41 dB 16 0 5 Locked QAM256 4 801000000 Hz 0.9 dBmV 41 dB 7 0 6 Locked QAM256 9 831000000 Hz 2.1 dBmV 41.2 dB 2 0 7 Locked QAM256 10 837000000 Hz 2.2 dBmV 41 dB 2 0 8 Locked QAM256 12 849000000 Hz 2.2 dBmV 40.8 dB 1 0 9 Locked QAM256 17 879000000 Hz 2.6 dBmV 41 dB 5 0 10 Locked QAM256 18 885000000 Hz 2.7 dBmV 41.2 dB 2 0 11 Locked QAM256 19 891000000 Hz 2.9 dBmV 41.3 dB 2 0 12 Locked QAM256 20 897000000 Hz 3.2 dBmV 41.5 dB 0 0 13 Locked QAM256 21 903000000 Hz 2.8 dBmV 41.4 dB 2 0 14 Locked QAM256 22 909000000 Hz 2.9 dBmV 41.3 dB 2 0 15 Locked QAM256 25 927000000 Hz 2.3 dBmV 41.2 dB 0 0 16 Locked QAM256 26 933000000 Hz 2.6 dBmV 41.1 dB 1 0 17 Locked QAM256 27 939000000 Hz 2.4 dBmV 41.4 dB 0 0 18 Locked QAM256 28 945000000 Hz 2.4 dBmV 41.3 dB 0 0 19 Locked QAM256 29 951000000 Hz 3.2 dBmV 41.5 dB 0 0 20 Locked QAM256 30 957000000 Hz 2.9 dBmV 41.6 dB 0 0 21 Locked QAM256 33 357000000 Hz -4.2 dBmV 40.1 dB 1 0 22 Locked QAM256 34 363000000 Hz -4 dBmV 40.4 dB 3 0 23 Locked QAM256 35 369000000 Hz -3.7 dBmV 40.4 dB 6 0 24 Locked QAM256 36 375000000 Hz -3.7 dBmV 40.5 dB 4 0 25 Locked QAM256 37 381000000 Hz -3.3 dBmV 40.6 dB 7 0 26 Locked QAM256 38 387000000 Hz -3.3 dBmV 40.5 dB 13 0 27 Locked QAM256 41 405000000 Hz -2.8 dBmV 40.7 dB 6 0 28 Locked QAM256 42 411000000 Hz -2.8 dBmV 40.8 dB 7 0 29 Locked QAM256 43 417000000 Hz -2.5 dBmV 40.9 dB 4 0 30 Locked QAM256 44 423000000 Hz -2.5 dBmV 40.9 dB 8 0 31 Locked QAM256 45 429000000 Hz -2.1 dBmV 41.1 dB 4 0 32 Locked QAM256 46 435000000 Hz -2 dBmV 41.1 dB 8 0
very hard to compare like that. if you're on windows, theres a screen snip function that lets me look at it much easier.
