dangermuffin
Nov 01, 2019Aspirant
Packet Loss with CM1200
So I've been getting really bad packet loss, after using ping plotter from my PC to trace the issue, I believe I've narrowed it down to the CM1200 modem. This is what my setup looks like.. modem...
dangermuffin
I didn't get a snip of the connections page or logs. I logged into my modem last night and didn't see anything like that. I'm at work and could attempt again in a few hours when I"m home.
and correct, that's how I have my setup modem > router > switch
Here's a screen shot of my PC plugged directly into the modem. For some reason it's appearing as that 10.xxx.x.x IP address but when I ran an IP config when plugged in it came back as a different IP.
Also wanted to point out that the response time with the modem according to ping plotter seems higher than it should be, even when plugged in directly!
Thanks!
Nov 01, 2019Guru - Experienced User
try this ping test. I've never used the you you're showing
- dangermuffinNov 01, 2019Aspirant
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 11 843000000 Hz 2.7 dBmV 41.1 dB 1 0 2 Locked QAM256 1 783000000 Hz 0.6 dBmV 40.8 dB 23 0 3 Locked QAM256 2 789000000 Hz 0.6 dBmV 40.8 dB 16 0 4 Locked QAM256 3 795000000 Hz 0.8 dBmV 41 dB 16 0 5 Locked QAM256 4 801000000 Hz 0.9 dBmV 41 dB 7 0 6 Locked QAM256 9 831000000 Hz 2.1 dBmV 41.2 dB 2 0 7 Locked QAM256 10 837000000 Hz 2.2 dBmV 41 dB 2 0 8 Locked QAM256 12 849000000 Hz 2.2 dBmV 40.8 dB 1 0 9 Locked QAM256 17 879000000 Hz 2.6 dBmV 41 dB 5 0 10 Locked QAM256 18 885000000 Hz 2.7 dBmV 41.2 dB 2 0 11 Locked QAM256 19 891000000 Hz 2.9 dBmV 41.3 dB 2 0 12 Locked QAM256 20 897000000 Hz 3.2 dBmV 41.5 dB 0 0 13 Locked QAM256 21 903000000 Hz 2.8 dBmV 41.4 dB 2 0 14 Locked QAM256 22 909000000 Hz 2.9 dBmV 41.3 dB 2 0 15 Locked QAM256 25 927000000 Hz 2.3 dBmV 41.2 dB 0 0 16 Locked QAM256 26 933000000 Hz 2.6 dBmV 41.1 dB 1 0 17 Locked QAM256 27 939000000 Hz 2.4 dBmV 41.4 dB 0 0 18 Locked QAM256 28 945000000 Hz 2.4 dBmV 41.3 dB 0 0 19 Locked QAM256 29 951000000 Hz 3.2 dBmV 41.5 dB 0 0 20 Locked QAM256 30 957000000 Hz 2.9 dBmV 41.6 dB 0 0 21 Locked QAM256 33 357000000 Hz -4.2 dBmV 40.1 dB 1 0 22 Locked QAM256 34 363000000 Hz -4 dBmV 40.4 dB 3 0 23 Locked QAM256 35 369000000 Hz -3.7 dBmV 40.4 dB 6 0 24 Locked QAM256 36 375000000 Hz -3.7 dBmV 40.5 dB 4 0 25 Locked QAM256 37 381000000 Hz -3.3 dBmV 40.6 dB 7 0 26 Locked QAM256 38 387000000 Hz -3.3 dBmV 40.5 dB 13 0 27 Locked QAM256 41 405000000 Hz -2.8 dBmV 40.7 dB 6 0 28 Locked QAM256 42 411000000 Hz -2.8 dBmV 40.8 dB 7 0 29 Locked QAM256 43 417000000 Hz -2.5 dBmV 40.9 dB 4 0 30 Locked QAM256 44 423000000 Hz -2.5 dBmV 40.9 dB 8 0 31 Locked QAM256 45 429000000 Hz -2.1 dBmV 41.1 dB 4 0 32 Locked QAM256 46 435000000 Hz -2 dBmV 41.1 dB 8 0
- plemansNov 01, 2019Guru - Experienced User
very hard to compare like that. if you're on windows, theres a screen snip function that lets me look at it much easier.
