chrob61
Sep 28, 2021Aspirant
Pairing up smart bulbs!
I have a Netgear AC1900 cable modem router, model c7000v2. I am at my wits end trying to figure out how to pair my smart light bulbs (Philips Wiz) trying to find the 2.4 ghz connection. I have l...
Sep 28, 2021Guru - Experienced User
Is your phone connected to 2.4ghz while you're trying to setup?
- chrob61Sep 28, 2021Aspirant
Yes I have 2 different wifi networks available on my phone, the Netgear5 and Netgear5-5G.
I went in to the settings using admin as username, and see that both networks are enabled and they are each called a different name SSID. I will again try the Philips Wiz chat option to see if they can help me.
plemans wrote:Is your phone connected to 2.4ghz while you're trying to setup?
- chrob61Oct 06, 2021Aspirant
One thing I have discovered while watching various youtube videos, is, that there should be a way for me to disable 5G wireless. So I went in to my router login, and unchecked the "Enable 5G". But then I got a pop up something like I cannot disable with WPA?? Not sure exactly the message....what I am getting at is this, isn't there a way for me to turn OFF 5G, set up my light bulbs with the 2.4 G , then go back and turn 5G back on??
- plemansOct 06, 2021Guru - Experienced User
Again, you shouldn't even slightly need to turn it off. You just need your phone to be on 2.4ghz. the lights won't pickup 5ghz if they don't have that option.
