mdzx111's avatar
mdzx111
Tutor
Jul 27, 2020
Parental Controls Nighthawk CAX80
Hello,
I just bought the Nighthawk CAX80 and I don't see parental controls.  What are my options?  This is crazy for the money I spent on this!
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    No parental controls at this time for the CAX80 you can look at a product by circle that gives your network parental controls.
    https://meetcircle.com
    DarrenM
    • mdzx111's avatar
      mdzx111
      Tutor
      Is there plans for the CAX80 to have parental controls?  I don't want to buy this device if a software upgrade will resolve.
      • En_Ay's avatar
        En_Ay
        Initiate
        I bought it and starting to regret it. Nothing but crickets from Netgear regarding parental controls on this device.
