marcusvan
Apr 15, 2020Follower
Passthrough mode nighthawk cm1200
Is it posable to put the modem in passthrough mode
- Apr 15, 2020
> No [...]
In other words, it has only that mode, so, if that's what you want,
then a CM1200 will do it. (You can't "put" it there, because it's
always there.)
Apr 15, 2020Guru - Experienced User
No as the CM model modes do no have a built in router. They are modems only.
- antinodeApr 15, 2020Guru
> No [...]
always there.)
