multiZ
Feb 07, 2024Star
password reset loop
Hi I've read several threads on this cax80 password reset loop problem, and no one has offered a solution. Looks like Netgear tech support rarely read these pages. I've seen messages dated dec 2...
- Feb 15, 2024
Thank you. I was able to log in.
I ended up doing a factory reset and then setting up the admin password.
Keeping my fingers crossed that I can log into the router the next time.
I had to reset a number of times.
I tried logging into the router without the coxial cable hooked in but that didn't work for me. I prefer setting up my router while being disconnected from the internet.
multiZ
Feb 15, 2024Star
Feb 16, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
